W203 noise on driving straight, silent on turning!
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by stephenmercedes, Jun 13, 2018.
  1. stephenmercedes
    stephenmercedes Hardcore MB Enthusiast
    645
    Apr 15, 2018
    UK
    Car:
    W203 C240 (LPG conversion)
    2001 W203 C240. I have a slight noise when driving, it's sounds almost like a small fan blade hitting an air vent, but it isn't! It doesn't seem to be speed related and maintains a constant volume. However, when I'm going round a roundabout, or turning a corner, it totally disappears! Any suggestions of where I should look?
  2. brucemillar
    brucemillar MB Club Veteran
    8,436
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    It could be the internal AC TEMP FAN/sensor. This uses a small fan behind a tiny grill on your AC head unit to draw air in over the sensor. Try blowing that grill out with some canned air?
    stephenmercedes likes this.
  3. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    Just bought a can online, that would be great if it was solved by that...
  4. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    Mixed result, I think it got a bit quieter, but I'm not sure, noise is still there! Is it worth shooting a squirt of WD40 into the vent? Would it do any harm?
    (Oh, now know why 'High Street' is disappearing, canned air online £2.50 inc P&P, pop into your local PCWorld/Curry and you'd walk out £13 lighter, yes, I know, for a can of air LOL!)
  5. Stratman
    Stratman Hardcore MB Enthusiast
    4,405
    Jun 15, 2003
    Sunbury
    Car:
    W203 C200 CDI '04Estate
    It's probably imported air, the kind you can walk on ;)
  6. HITECH
    HITECH Hardcore MB Enthusiast
    442
    Dec 25, 2014
    coldest place in scotland
    Car:
    C220 CDI
    Sounds more like a faulty A/C motor actuator arm. Click click click, maybe go away with g force from rounding a corner..... I wouldn't recommend spraying any kind of grease or flammable liquids in your vent bud. There are tons of threads on air conditioning motors, flaps, broken arms.... have a look. maybe its your problem. maybe not.... Unfortunately I have this problem with mine which means stripping the dashboard apart to change the motor with the broken arm on it.
  7. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    Too late LOL I sprayed it last week but it made no difference at all. I've learned to live with it, in the grand scheme of life, there's plenty of other stuff for me to worry about! :)
  8. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    Right, thought I'd give this a wee bump as the noise is getting worse (louder), here's a summary:
    1. Sounds like a fan blade rattling or hitting something, but it isn't.
    2. On increasing speed, the noise intensifies but does not change in pitch
    3. Below 10mph, you can barely hear it at all, (but impractical to drive everywhere at that speed!)
    4. When bearing left, or turning left, it totally stops, but continues on straitening up.
    OK guys, let's hear your best shot...
  9. andy27168
    andy27168 Hardcore MB Enthusiast
    4,291
    Nov 27, 2004
    Southampton
    Car:
    1997 C230K, 1999 C43/55 AMG
    Sounds to me as if you have something wrong on the passenger side front wheel/suspension, tyre, wheel bearing maybe, possible worn ARB or suspension bush.
    I would start by jacking up the front removing front wheels, and have a good look, checking for wheel bearing play, use a lever bar and check for wear in the ball joints, excessive play in the suspension arms, check both sides so you can compare any play from one side to the other.
    When putting back swap the wheels from one side to the other (do check tyre sidewall to ensure the tyres are not directional).
    Swapping the wheels should tell you if the tyre is the cause if the noise transfers to the right side.
  10. alecmascot
    alecmascot Hardcore MB Enthusiast
    177
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    Any chance that you can post a recording ?
  11. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    mmm...You are speaking to an analogue man in a digital age LOL I could possibly have a go at recording it on my 12 year old Nokia (it does have that function) but the process to then upload it for an analysis may well be a step too far. I'll see what I can do... :)
    clk320x likes this.
  12. Stratman
    4,405
    Jun 15, 2003
    Sunbury
    Car:
    Could it be be that perennial favourite the parking brake cable?
    The plastic retaining clips holding it to the propshaft tunnel become brittle and break, allowing the cable to rub against the propshaft. The noise can stop going round corners as insufficient centripetal force allows it to move away from the shaft, only to rub against it again on the straight.
  13. alecmascot
    177
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    That would fit everything but condition #2... does not change frequency with speed.
    If it really does not change frequency with speed then it cannot be caused by any driveline or engine component.
    That leaves us with in-car systems like climate control.....
  14. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    OK, We have a WINNER!!! Startman was absolutely 100% spot on with the diagnosis. I brought my car in earlier to my local 'indy MB' garage. The guy took it for a test drive and diagnosed the noise within seconds, confirming it was the parking brake cable clip that had broken.
    He put it immediately on the ramp, repaired same, than replaced my drivers side air vent I've had in the boot for ages to replace the existing broken one where the slats were not operational. He also, on dismantling that part of the dash noticed the handbrake pull lever was cracked, and he replaced it with a spare he had. In addition, he also installed 2 x xenon headlamp bulbs I had in car which I had intended to replace myself at the weekend. Considering I was a 'walk in', the service I received was absolutely outstanding, and the cost, well it was so little I'm a bit embarrassed!
    Belfast area:
    Creevy Autos - independent Mercedes Benz Specialist - Belfast,County Down-Northern Ireland N.I.
    Stratman, Smart320 and Flyinspanner like this.
  15. alecmascot
    177
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    Glad it worked out for you, but you misled all of us when you said it was not speed related......
  16. OP
    OP
    stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    Not sure how, it got louder as I went quicker (as stated) but to me, it just stayed the same 'noise'. Anyway, all good now...
Share This Page
