deian
Hi again,
My new (to me) w203 estate doesn't seem to be blowing cold air from outside, I think (sure) it has AC (will renew the gas when I know it's blowing the coldest without it), but with the fans on the coldest settings and the AC off it's still not as cold as the air from outside if I put my hand outside of the window.
I've seen this filter thing above the battery, surely the air intake doesn't come through from there (as in from above the battery), this would suck warmer air from inside the engine bay right? Is it not directed from the outside?
(OR lets assume the above it not the issue)... Could it be that the electronic flaps that control the air flow temperature (through the matrix), or the water temp through the matrix doesn't fully get to it's extremest setting to let the temp be cold?
Ahh, annoying! I'd like to set it to Auto and have it settle down when it reaches the temprature. Any ideas? Thanks
Deian
Deian
