w203 parking brake problem
culpano
Fleetwood, Lancashire
Mercedes E350 CDI Coupe
Anyone had a problem where the parking brake won't quite release all the way so the red warning light stays on. Then when driven a bit further the big red parking brake light comes on and a shrill beep sounds. The only way to get rid is to put my foot behind the pedal and pull it back.
Flash
UK
Mercs
Looks like another trip down to the Stealers for you under warranty again....
Gunny
Guisborough Cleveland
1999 CLK 320 elegance 2001 C200 Kompessor Avantgarde
This is caused by a build up of brake dust on the hand brake shoe ratchet adjuster - requires removal of rear discs & a good clean out with brake cleaner, wire brush etc.
You may find that if you press the hand brake pedal down really hard it will spring up with no problems - if you tend to be a bit girly with it - this is when they tend to stick.
Gunny
C Class gone - replaced with SAAB 93 TURBO Auto(with proper hand brake)
850t5
Cranbrook, Kent
Volvo 850 T5 Estate
The 203 C Class's rely heavily on parking brake shoe and cable adjustment to pull the pedal all the way up (and put the warning light out). Unfortunatley 'adjustments' are not covered under warranty but any self respecting dealer should carry out the adjustments as a gesture of goodwill!! :crazy:
ddentrec
Cambridge
W123 280TE, W123 200T, W203 C180K
Be warned culpano: parking brake on my 2003 C-Class never worked properly--even after the A-service. Then at the B-service they found it had been eating into the disks--these had to be replaced under warranty.
Also, parking brake problems are not an unheard of issue for the stealers...get things done sooner rather than later ;)
AMGBoy
any mercedes
hi
the linkage which is under the rear seat for the handbrake sezes up so it doesnt turn the light off
if you remove or lift up the rear seats there is a black cover in the middle if you remove the cover you will see the linkage you will see whot i mean knock it and it will return all the way and your light will now be off
lub it and work the handbrake it will free off
hope this is ok
Wild Woods
Cheers for the info.
Had my footbrake sorted a couple of times while under warranty but the problem returned shortly afterwards. Now it's out of warranty I will have to try a spot of DIY.
Wild Woods
Thanks AMGBoy for the info. Freed up and applied plenty of lube. Not suprised it plays up as the exhaust just underneath it must heat up and dry out the lube.
Mercezian
London
C220 CDi SE 2005
C220 w203 hand brake warning light
Had the same issue and its sorted now. Rusty mechanism causes the problem but once oiled / greased, should work OK.
