Right i got in my good ladies car the other day went to start it and instead of the usual click whoomph start, i got a slow turning engine that then fired.
When back home i measured the charge rate 13.8, then lights and heated rear screen on it dropped to 13.45 which whilst a tad low i reckon is okay.
I then took the car to work and tested the battery with the midtronics machine, which told me 12.17 volts good recharge, i entered 800 cca and it tested at 709cca.
I have also noticed the dash info panel slightly faded at the top and bottom of the screen, i recharged the battery and on the drive home the screen was perfect.
Checked the battery today after stood for 5 hours and it was 12.17, bit low i thought, started the engine tested at 13.8 and dropping to 13.50 as before.
Im leaning towards a battery but dont want to spend a 100 quid if its another fault.
Is there any known faults with something pulling the battery down?
Sorry its a bit long winded
Lynall
Lynall
