iainsherriff
STUCK IN UPRIGHT POSITION.
Loads of part posts about this but no solutions that I have found.
So I just waded in. It was the 40% part in mine. Release handle not doing anything.
I will do a full how to when I reassemble but basically you need to remove all the upholstery and padding, remove the bolts holding the latch mechanism in place, click off the inside latch cover...then you can get a screwdriver into the mech to open the latch, and finally remove the seat.
The problem is a small bit if plastic !!
