my daughter's c230 1.8 Kompressor wont start ... engine not turning over.
recent history ... engine management light on due to failed o2 sensor (upper) caused by oil leaks on both cam sensors then getting into wiring loom. So I replaced both cam sensors also fitting an intermediate connector as preventative, then replaced both o2 sensors and gave connectors a thorough clean with electrical contact cleaner. There was evidence of some oil having leaked into rear connector of ECU which I have cleaned our three or four times over last two weeks. all above undertaken two or three weeks ago. all running well and having cleared engine management light didn't come back on.
on friday whilst I had car i decided to also change automatic transmission oil and filter. also gave the ECU connector another clean as still some faint traces of oil. After started first time and I drove about 8 miles with all well and no lights on.
Saturday morning when turned ignition lots of lights on ... yellow ESP, red brake, red SRS, yellow engine management, and low fuel light on (despite half a tank with gauge acknowledging that). On turning ignition engine doesn't turn over. The battery is less than two months old. Lots of other electric working fine including all lights, windows, air con etc., radio.
Help ! has ECU failed?
david
david
