Hello all,
I was out driving a couple of days ago, I braked to stop and talk to a neighbour and 'EBD,ABS,ESP inoperative See owner's manual' came up on the display when I set off again. At the same time the steering became stiff and there was a message 'Run flat indicator inoperative'. The indicators/lights for ABS and traction control also came up. If I stop the car and restart the messages go away until I reach 10-15 mph.
I wasn't overly concerned as I thought it sounded like a wheel speed sensor.
I have a Delphi ds150e diagnostic scanner which obviously crude compared to the Merc Star system. The Delphi scanner came up with 2 fault codes '5945 ESP/BAS control module internal fault, intermittent' and '5001 ESP/BAS control module internal fault, intermittent', no mention of wheel speed sensors.
I have found a company that repairs ABS modules for W204 in the UK at around £200 + VAT (12 months guarantee) although they don't quote the part number for the C63, A2049005403. The advantage of this is that I can fit it myself in 10 minutes and it doesn't require to be coded. The other sensible option would be to get a used one from a breakers, but that would require coding. I think a new ABS module from Merc is around £1000 + VAT.
The only thing that bothers me is the message, 'run flat indicator inoperative' which would lead me to wheel sensors.
Would a faulty ABS module cause the run flat indicator to be inoperative?
Nigel
Nigel
