6cyl
Any one use non-MB brake pads ?
The MB ones are too dusty !
Be wary of discs wearing down if you swap for harder pads. I've certainly noticed the wear on mine, at only 22k miles (still on original pads). Will probably need replacing in another 10k miles.
Similar price to the EBC's EBC Greenstuff Front Brake Pads for MERCEDES-BENZ C-Class (W204) C350 TD 4-Matic | eBay
Can't believe the prices are so high to be honest.
Do you just brake gently or do you occasionally do a hard stop? Disk brakes do benefit from a hard stop to clean them up (my old 1999 C240 had instructions explicitly stating that I should do a hard stop on a regular basis). I have a very low mileage Vito and the brakes get quite squeally but will clean up with a firm stop or two.Mine also squeal when braking, but only when gentle braking. Any pressure at all and the squeak stops. So it can't be the wear indicators in my case anyway. Also the squeal doesn't happen all the time, only about half the time.
they are noisy don't buy them!
i fitted the on my 63 at rear and when hot you get the occasional sqweek .WG M-B said:interesting thanks for the feedback! I havent used them as yet, although i find regular textar very good. Pagid, however, i find a bit hit and miss with noise
