w204 c clsss key wont turn in ignition
Discussion in 'Electronics' started by BillyW124, Jun 3, 2012.
  1. BillyW124
    BillyW124 Hardcore MB Enthusiast
    2,890
    Oct 22, 2010
    North West London
    Car:
    W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
    Hi Guys,
    As above, a C class 204 that locks/unlocks the door's, but when you put the key in the ignition there is no sound of electronic ulnocking of the steering column and you cant turn the key?
    any ideas?
    Have not tried the spare key as it isn't available to hand.
    could it be a key fault, or somthing to do with the electronic barrel not recognising the key i.e. lost its programmed signal etc?
  2. markjay
    markjay MB Club Veteran
    24,578
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    I have no idea, but as no one seems to be around to offer any qualified advice... have you checked the fuses ?
    Always a good starting point with electrical problems ...
  3. Dec
    Dec Hardcore MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
    Key could be broken… was it dropped recently… the spare key will prove whether your current key is faulty… if your spare works ok then your current key is faulty.
    Dec
  4. ucr
    ucr Hardcore MB Enthusiast
    1,073
    Dec 8, 2010
    Car:
    car
    car may have a flat battery Check and charged
    1 person likes this.
  5. DSM10000
    DSM10000 MB Club Veteran
    6,751
    Jul 12, 2011
    Near Salisbury
    Car:
    E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
    You need to check with the spare key but if the same symptoms are present it suggests that the problem lies with the ignition switch assembly.
  6. OP
    OP
    BillyW124
    2,890
    Oct 22, 2010
    North West London
    Car:
    Thanks guys, will need to check with the spare first...
  7. knighterrant
    knighterrant Hardcore MB Enthusiast
    3,496
    Mar 2, 2012
    Here
    Car:
    Yes
    I may have misunderstood the symptoms, but it sounds like the classic of the gearbox not fully into Park. Shift the gears around a bit and return to Park then try it. Alternatively it could be that the steering lock has come on in a position that puts a slight strain on it and is preventing the key from turning. Wriggle the steering a bit and try again. Both simple solutions to a surprisingly common problem.
  8. OP
    OP
    BillyW124
    2,890
    Oct 22, 2010
    North West London
    Car:
    spare key doesnt work either!
    when its inserted you can hear a faint ticking sound so it seems to be wanting to do somthing.
    i also noticed the interior lights when manually pressed doesnt come on.
    They do however come on when you lock/unlock using the fob. i'm wondering if it is a fuse or electrical problem.
    fuses look to be ok.
  9. Justin1600
    Justin1600 Hardcore MB Enthusiast
    2,079
    Dec 28, 2010
    Car:
    C43 AMG
    Check that you have at least 12v at the battery first, if so then probably the EIS at fault.
    Remove the drivers dash undertray, un screw and drop down the EIS then tap it with a screwdriver while trying to turn the key in it. Sometimes they spring into life, but will need replacing at a dealer :thumb:
Share This Page
