Hi guys
can anyone tell me where the fuel temperature sensor is located?
I have the following code showing P0183 Fuel Temperature Sensor A Circuit High Input
Many Thanks
Hi Mazzz,I’ve not really replace the sensor yet it’s due to come through the post today. After some research it’s in front of the engine I’ll attach a image I’ve seen online
Hope it helps lads. Does anyone does when engine is dipping in power 1/2 seconds is that caused by this sensor or isit a fuel filter issue (I’ve changed this but no luck) or isit a injector ?
Hi Mazzz,
Did you replace your fuel temperature sensor? Is the sensor the one in the picture you uploaded with the green arrow pointing to it? Thanks.
Hello wingo,
Yhh I replaced it and I’ve not had the engine management light since. Also I haven’t had any dip in power either
Yes it’s as simple as that I did it in my garden, hope it gets sorted lad
Mazzz, Thanks for the info. I have the same problem on my W204 here in Australia. Can you tell me where you got the part? I am having trouble getting one here. If it was a genuine Merc part, do you know the part number?Yes it’s as simple as that I did it in my garden, hope it gets sorted lad
Did you sort it Greg ?Mazzz, Thanks for the info. I have the same problem on my W204 here in Australia. Can you tell me where you got the part? I am having trouble getting one here. If it was a genuine Merc part, do you know the part number?
Replaced mine just recently. It would, on occasion, have split second where I could feel a loss of power. The sensor is in the front of the engine, just underneath where the air intake runs across it. Just un-clip the wire and undo it. You’ll see fuel in there when you remove it. After this I had no more blips and the code could be cleared. Sorry, it won’t let me upload a picture of it.Hi guys
Many Thanks
