Hi all,
Hope you are well.
I have just acquired a 58 reg C320 CDI saloon and the battery seems on its way out as even after a 2 hour drive back home, its voltage is still showing 12.1V (was also 12.1V when we went to view the car).
I am shopping for a battery however, I need to know if the car needs to be told that a new battery has been put in because it appears it has the IBS (intelligent battery system) module on the negative terminal wire. In my brother's 2008 330d which also has the IBS on the negative terminal, the Power management ECU had a "battery reset" option which was reset when the new battery was installed.
Also, by looking at the battery, it doesn't appear to be a AGM as there is no mention of this on it, can someone confirm if these cars had AGM or NON-AGM batteries?
Any advice would be highly appreciated.
Hope you are well.
