Hi all,
I'm new to this forum, so apologies in advance if I'm not following any rules.
I've just bought a 2011 W204 from Mercedes Hemmel Hempsted. It does not have any obvious problems, but I decided to do a diagnostic using Carly just to double check.
The report said there were four faults and the most worrying one was with ESP. The problem is, it does not say what the actual fault is, instead I just get this:
ESP - Electronic stability program (MB: NO_HWID_FOUND)
Sorry, there is no explanation available
Code: 313732
Code: 303134
There are also problems with Audio and it just says:
Audio 20 / COMAND - Audio or COMAND (A2 - A40/3) (MB: 2049012303)
Fault: ECU reset/recovery occurred
Code: 001614
I googled the codes, but couldn't find anything. Does anyone know what these mean?
I'm also attaching the full report if anyone wants to see.
Thanks very much in advance!
Code: 313732
Code: 303134
Code: 001614
