Daft question but are you sure it was the shocks and not just the mounting that was causing the knock?
Hi Grober, I’ve replaced the shock absorber and the complete bearing that mounts it to the body at the top of the shock and the drop link but still getting the dull thudding at low speed over bumpy roads, it’s driving me crazy! Can you recommend the next bit to replace please? Is it the item the red arrows points to? and what do they call it??Assuming you have had the ARB links and the lower control arms changed at the front Maybe its the torque arms- they are a known weak spot on the w203 and w204
Mercedes-Benz W204 Torque Strut and Bearing Replacement - (2008-2014) C250, C300, C350 | Pelican Parts DIY Maintenance Article
Torque Arm Bearings Popping...again - MBWorld.org Forums
If these are the "lowercontrol arms" you referred to already then ignore this suggestion---[terminology can be misleading and I may have misunderstood ]
Thanks Grober, I’ll try that part nextSEE POST 3 Of this thread. item 200 in the diagram
STEERING KNUCKLE AND CONTROL ARM MERCEDES C-KLASSE [Car] [CHASSIS] (EUROPA)
