ragazzi
Hi all,
I haven't posted for a while as last time I got a good amount of responses due to the auto gearbox transmission fluid service that cost an arm and a leg, anyway my new predicament.
My car is registered September 2010 so it is out of warrant and has done 49k miles.
In January 2015 my coolant light came on, I thought it was strange (it hadn't happened in the many years I had the car and I had kept a good service history etc.)
I rang one main dealer they said top up with water as it is an air bubble that can sometimes happen
I then rang another dealer to verify this and they indeed said it is protocol so I topped it up.
For the next 2 and a half months I topped my car up with water as the light would come on once every weeks initially until it was close to once every 3 days.
I tried a new coolant cap, £18 it cost me and it didn't fix it. The lad on the parts desk said my engine had the code that could have a faulty batch of water pumps.
Mid-March 2015, I rang the main dealer and mentioned my predicament. The nice chap agreed that a car with such low miles and in such an age shouldn't be experience this and then I asked the cost of a water pump he said it would cost £600 but MB will contribute 50% a goodwill as it is strange for it to occur a this point in the cars life.
He then proceeded to mention it will undergo a stress test before they order and replace the water pump as they need to be certain.
He confirmed it was the water pump and I booked it in.
2 weeks ago the part arrive and I had the water pump fitted at 50% cost.
2 days later the coolant light came on again.
I rang the main dealer they said it is the air bubble that could cause the issue and top it up with water
So I put in 500ml of coolant (as I read water isn't the best thing to use)
Yesterday my coolant light came on again, so I rang Mercedes. He mentioned it could be the air lock to which I said it can't be as it was 500ml I filled up with.
Car has gone in today, they have done a stress test and said it is the coolant outlet seal that is leaking ever so slightly.
Then I was told the new pump has restored the original pressure in the coolant tank and that under the stress this has made the sealant go on the coolant outlet.
He said its £4 for the seal but more importantly could cost a few hundred to fix as it is the labour involved. He is speaking with MB for a goodwill gesture to see what they will do as it is still strange.
Am I having my pants pulled down?
My gut feeling is the following :
What should I do? I have an invoice sheet that says
Water Pump Remove/Install, Inspect and if necessary replace.
- The test wasn't done correctly initially. (took 20 minutes)
- It has always been the seal
