W204 DAB Radio Options?
flowrider
United Kingdom
SL500 (R230) / Audi S5
I just had DAB fitted to my W204 today from a company called justconnectme the product I have is the justdrive it was £180 and is an FM transmitter so it uses a spare FM signal the chap has programmed it to preset 0 so when my daughter is in the car and she doesent want to listen to dads old music I can just hit preset 2 for kiss fm and then back to 0 for DAB the gadget is behind the dash somewhere you wouldn't know he has been in the car apart from a thin aerial stuck in the top left corner of the screen,the gadget works by remote so you have a tiny remote control which you can search and store your DAB stations on,i have had this thing fitted on 4 of my previous cars and haven't been able to fault it once.
Sounds very similar to the Pure Highway products. I have a Nextbase DAB+ adapter in my SL, it works great and only cost £32.
OP
OP
mpc
mpc
2011 W204 C250 CDI Estate
For the princely sum of £25, in my old car (prefacelift, back in 2014) I got a Bush DAB usb dongle and it worked flawlessly
Plug the aux lead in on one end, plug the usb in the other end for power. Select your station and enjoy. I imagine nowadays there’s plenty of dab dongles around
What did you use for an aerial?
14emerc
E class 220cdi
My 2014 has DAB. Never been impressed with the reception when using DAB, too much dropout. Thank goodness that FM lives on.
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
I had a device the connected the kids iPhone to COMAND via the FM radio, it generally worked well, only issue was that when traveling outside London the radio stations' frequencies would change and occasionally the free FM channel that we used in town no longer worked and we needed to change channel.
ash59fifty-uk
The shire
C204 C63, VW Transporter
Can you still buy these? Got any web links to one?
Something like this would suffice, although they seem to have changed since I owned one
I only ever listened to 1Xtra or Kisstory so I’d usually set the dongle to a station and leave it tucked in the glovebox. This unit looks more ideal as it comes with cables, and you can mount it where you like for easy use ~
Pure Highway 200 In-Car DAB+/DAB Digital Radio FM Adapter with AUX Input for Music Playback – DAB Car Radio Adapter/Transmitter, Black https://www.amazon.co.uk/dp/B077ZYXVWW/ref=cm_sw_r_cp_api_i_sfjjFbX5AP97B
OP
OP
mpc
mpc
OK, i liked the sound of what you had as there was no ugly aerial stuck to the windscreen and nothing could be seen. Everything i see now online looks like a USB stick with an aerial attachment.
ash59fifty-uk
The shire
Oh I see what you mean, it has an aerial. I thought that was just a picture of the aux lead
Something like this is what you want. Just need a micro USB > USB adapter (between your car usb and the unit) plug your aux into the headphone slot
keyword with players/dongles like these would be ‘personal dab player’, you just need a powered one via a USB lead as opposed to one that plugs into either mains, or the cigarette charger. Your car (aux) is essentially the headphones
Portable DAB/DAB+ & FM Radio, Rechargeable Battery Powered Portable DAB Radios Pocket Digital Radio with USB Charging for 8 Hours Playback Portable DAB/DAB+ & FM Radio, Rechargeable Battery Powered Portable DAB Radios Pocket Digital Radio with USB Charging for 8 Hours Playback: Amazon.co.uk: TV
