W204 Disk wear.
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by Colin_b, Nov 18, 2015.
  1. Colin_b
    Colin_b MB Enthusiast
    1,780
    Jul 9, 2007
    Leicester
    Car:
    C250CDI (C320CDI & SLK350, Sold) & the Trusty Citigo
    Just had my 2012 C250CDI serviced. No surprises, except front brakes. The car has done 30,000 miles, and the front disks/pads looked OK for another 5 to 10 thousand miles.
    However the dealer says the disk is down to the minimum (26mm), but the pads are OK, 5mm+
    £423.64 to fix!
    Are W204 disks prone to wear fasted than pads? seems a little unusual.
    Anyway, I'll replace the disks/pads myself, it looks fairly straightforward.
  2. Jonesy161
    Jonesy161 Active Member
    228
    Apr 6, 2015
    Car:
    W204 c220 sport
    Exactly the same situation as mine, discs are well down but loads left on the pads. Very easy to do, I think you can get the bits for about £120.
  3. Del80y
    Del80y Active Member
    132
    Jan 29, 2014
    Glasgow
    Car:
    C220 Estate Sport 125
  4. DrFeelgood
    DrFeelgood MB Enthusiast
    8,990
    Nov 10, 2005
    Car:
    BMW 740Li
    I'd get a second opinion.
  5. ash59fifty-uk
    ash59fifty-uk MB Enthusiast
    3,692
    Aug 9, 2015
    The shire
    Car:
    W204 C63, Ford Transit
    They said the exact same to me with similar price at my service, sent via video. Obviously I declined
  6. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,808
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    You could just wait until the pad warning light comes on.
    3 people like this.
  7. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    Isn't that dangerous? Wouldn't it take the discs below minimum if the pads still have 5+mm on them?
  8. Ginger55k
    Ginger55k Active Member
    752
    Aug 2, 2012
    Hampshire
    Car:
    2 taxis Serviced by PCS
    Funnily enough that's what the stealer said to me many years ago, and then I found Olly and PCS who ordered up all the parts to find the discs were no way near the the minimum, in fact 2 to 3 mm more meat on them.
    Never been back to a stealer since.
    Get a second opinion :D
  9. BlackC55
    18,808
    Feb 8, 2007
    Car:
    A set of pads should last a set of discs. I'd measure them again to be sure
  10. hotrodder
    hotrodder Active Member
    845
    Sep 28, 2008
    south east
    Car:
    '93 320te
    I'm amazed that they said 5+ mm of pad left is OK* but I wouldn't be surprised if the dealer is quoting MBs 'service limit' which is different to the actual min disc thickness, probably 25.4mm if they're 28mm new and MB say 26mm is the min? My s124 for example... 294 x 25mm front discs, the MB service limit is 23mm while the actual min thickness is 22.4mm. Below this they obviously become more prone to cracking and fade (less material = less of a heat sink) but it's not like they'll instantly fall apart... not recommended but there'll be another several mm at least before this happens
    [​IMG]
    * Obviously it is but stealers often to want to replace pads with even more life than that left in 'em to [cough] lessen the chances of you being 'inconvenienced' between services [/cough]
  11. Auto-mobile
    Auto-mobile MB Enthusiast
    1,600
    Oct 1, 2011
    Birmingham
    Car:
    2x c43 Amg clio 172 turbo 314bhp
    As olly said, run them until the light comes on.
    And yes w204 disks wear very quickly.
  12. DonVitto
    DonVitto New Member
    24
    Oct 4, 2015
    Car:
    Mercedes C180 CGI Sport
    My front discs looks heavily worn to me (by eye) but when I had it serviced recently the independent specialist I use said they are good for another 20k miles!
    I did enquire about having them changed and was quoted £250 I think.
  13. Spitfire
    Spitfire Member
    53
    Sep 16, 2015
    Norfolk
    Car:
    C350 Coupe AMG Sport, V6 Petrol
  14. TomMusa
    TomMusa New Member
    5
    May 31, 2015
    Liverpool
    Car:
    C250 CDI Coupe AMG Sport Plus
    exactly the same with my 62 plate c250! serviced at 27K miles, front brakes pads and disks require replacing, I was quoted £350
  15. OneForTheRoad
    OneForTheRoad MB Enthusiast
    2,330
    Apr 20, 2015
    uk.
    Car:
    2015 w204 c class amg sport premium +65 ford kuga 2.0 cdi zetec awd..
    MB £ 382.86 for front discs and pads on my car - did them myself pagid parts £98 .
    MB £ 131.81 for rear pads - did them myself £ 25 pagid pads .
  16. geraldrobins
    geraldrobins MB Enthusiast
    1,441
    Jan 26, 2013
    Car:
    VW Golf, past c200cdi
    I'm still on original pads and discs at 48k, and nothing reported at last service and MOT in September. Maybe they didn't check them! but they look ok to me.
    1 person likes this.
  17. knighterrant
    knighterrant MB Enthusiast
    3,515
    Mar 2, 2012
    Here
    Car:
    Yes
    Those parts sound good value. I changed the discs and pads on my Porsche 944 four years ago and the cheapest I could get the parts was about £350.
  18. paulshep69
    paulshep69 Active Member
    792
    Apr 12, 2014
    Elgin, North East Scotland
    Car:
    C63 AMG Palladium Silver
    Mine is still on its originals too at 40k, they were reported as needing replaced 2 services ago, because of corrosion. I bought new ones myself from MB but still haven't changed them. At this years service, they said they were 60% worn, they were obviously at it last year.
  19. Auto-mobile
    1,600
    Oct 1, 2011
    Birmingham
    Car:
    Is your car a w204?
  20. geraldrobins
    1,441
    Jan 26, 2013
    Car:
    Yes it is.
Tags:
Share This Page
