W204 door lock prob
R2D2
C350
The doors on my car operate in such a way that even if they are locked, pulling the silver lever will unlock and undo the door. Except that the passenger front door takes one pull of the lever to unlock and a second pull to undo it. MB say I need a new lock and quoted 00s to do it. Any one else dealt with this issue?
I thought the 'two pull' passenger handle was normal? will try my own car to double check.
Could you. Cheers that would be helpful :)
Just asked the wife, she says it's a single pull, on my 2008 W204
Just tried mine and a single pull on the lever is all that was required. I have had other cars though when one pulled unlocked and a second pull was required to open. I wouldn't spend money on a fix if it happened on mine.
I've also checked mine, and it's a single pull. My last car a BMW needed 2 pulls to open a locked door.
Aha! There you go, Greg, your car thinks it's a BMW. The indicators will stop working next...
mine n mates 204 is 2 pulls ... now im confused!! i always thought the w204 is 2 pulls...
??????????????? Even more confused:crazy:
