Superdunx
- Jun 26, 2014
- 2011 W204 C200 Cdi Elegance Blue-Efficiency and 2000 W202 C220 Cdi Classic
Hi all, I'm new to the forum despite having owned, maintained and driven a 2000 reg W202 for the last 12 years and 220K miles!
I have recently purchased a 2011 plate W204 estate and have a set of genuine Merc mudflaps to fit. The front mudflaps look quite straightforward and come with all fastenings.
The rears are where it gets interesting. The problem I have is that amongst other fastenings, the mudflap picks up on a stud and threaded nut that goes through the trailing edge of the wheel arch liner. The thread on the drivers side is not long enough. On the passenger side, the thread is a good 5mm or so longer than the plastic nut so fitting should not be a problem, but on the drivers side it doesn't even show through the nut and you can't even get the thread started when the mudflap is in place. I would have thought that the threads would be the same length on each side, but it appears this is not so.
So A couple of questions, firstly has anyone fitted these before and can anyone provide any fitting instructions or advice?
Secondly am I missing any of the parts? e.g. should there be a longer threaded insert in the fitting kit?
Any help or advice gratefully received! FYI the Merc part number of the mudflap kit is A2048900178.
Regards,
Duncan.
Regards,
Duncan.
