Sadham
when cold it works fine nice gear changes etc.
When warmed up and driven for a while about half an hour to 45 mins then it loses drive.
If I put the accelerator down fully, revs will go up, when it passes 2500rpm it tries to move sometimes does move a little bit and vibrates violently as it moves. then revs drop and go up again even though pedal is still kept down.
reverse and drive is the same.
once cooled down it works fine again.
No lights on dashboard. any ideas what could be cause and what i can do to try and fix?
