W204 front coil springs
Gazwould
Everywhere
S204 C250 CDI AMG Sport
They will lower an AMG Sport only very slightly around 10mm.
LEB do you have a wagon or loon ?
steveq
Dublin
2011 S212 E220 CDI Estate, 2011 W204 C220 CDI, 1965 230SL Pagoda
You're missing the point , the other spring might not be far behind snapping .
Actually, no I'm not missing the point.
The spring had snapped and not worn out.
I don't know if it was a fault in the spring or the wheel had hit a pothole previously. Either way, it just snapped.
If the OP uses a different brand or spec of spring than definitely both sides should be replaced.
I replaced with an identical MB spring with the same colour markings.
I had the car for about two years after I replaced one spring and the other side was fine.
I am not saying that you shouldn't replace both sides but just that it isn't mandatory.
Replacing shock absorbers is different. If one side is worn out, they should be replaced in pairs.
mikrt
Cardigan
2013 C220 CDI BlueEFFICIENCY AMG Sport Plus 7G-Tronic Plus 4dr
Hi OneForTheRoad just checked spring it has 3 red dots and a white. It also has a barcode label with B2 on it.
Got a pair of Monroe SP3845 from Autodoc earlier this year, 3 x red & 1 x white, I think about £80 for the pair delivered.
Blue30
C220 CDi
^^ I got Monroes from Autodoc last year too with the right dots on, they’ve been fine
