Graham Baxter
- Sep 5, 2015
- C220 Cdi 2013 Executive SE Blue Efficiency
I have a Dec 2012 W204 C220 CDi Executive SE Blue Efficiency.
My problem is trivial but I have been unable to find a solution.
There is an instantaneous MPG meter together with a remaining range which displays on the speedometer, which only seems to go to 40 MPG. And there is a bar graph on the Audio 20 screen which shows historic fuel consumption. But everything over 50 MPG is sliced off. The graph scale goes higher, but the bars never go above 50. Consequently I have a meaningless graph with mostly identical results since a typical MPG figure is nearer to 60.
Is this a bug or a feature?
