W204 intelligent light system - No Kick up
wiggo220
South East
C220 AMG sport plus Estate
I've recentley purchased a 2012 (62) C220 sport plus which has the intelligent light system.
On the last MOT it had an advisory notice for "NO KICK UP ON OFFSIDE HEAD LAMP"
Can this be adjusted or fixed?
On start up they move up and both seem to self adjust Ok.
Any help would be greatly appreciated.
Cheers
Matt
I purchased a C220 Coupe with the ILS, the auto main beam did not function, when checking the settings the headlights were set for right hand traffic, setting for UK cars should be left hand traffic, might be worth checking as this may also affect the Kick up pattern.
Settings can be checked/changed via the on-board computer
Press the < or > button on the steering wheel to select the Settings menu.
Press the up or down button to select the Light submenu.
Press OK to confirm.
Press the up or down button to select the Dipped beams Setting for: function.
You will see the selected setting: Right-side traffic or Left-side traffic.
Press the OK button to save the setting.
If you change the setting, conversion does not take place until the next time the vehicle is stationary.
