Hello I could do with a little help...
I am getting error messages for
Rear left turn signal
Rear left brake/tail light
continuity check of all bulbs show they are fine and the connections in the bulb holder are also OK.
Switching off and restarting the car clears the errors for a short time then they will reappear. I am assuming it's going to be the rear sam module at the moment.
I would welcome any other suggestions though, in addition can anyone suggest someone for repair of the module rather than replacing?
Thanks.
edited to add: If driving without braking (motorway for instance) the turn signal error is not triggered when indicating, indicators will work normally. Once the rear brake/tail light error is triggered, the turn signal error will appear on the first use of indicators. Hopefully that makes sense.
Thanks.
