W204 p2463 fault
Christian6287
Telford
w204 C220 CDI
Hi i am currently getting the P2463 fault code, i had a split intercooler pipe replaced with a genuine MB part. It then threw up the code at first no EML was not on but was definitely in limp mode would not rev above 3000rpm etc. told by MB dpf needs clean and to replace the pressure sensor so I replace the sensor and got in contact with mobile cleaning service £210 later the gent says he has cleared the dpf checked all the system including pressure sensor and egr all os good but cannot clear the code as it is a permanent stored code. He said it needs to go to MB to be wiped using star. Is this true? I have a generic torque OBDII reader and have noticed before even starting the car it comes up as a pending fault even after clearing the faults turn the ignition off turn it back on the pending fault is back and the car is in limp mode. After a short while the EML light comes on. Any help would be greatly appreciated
