khimani_mohiki
- Jul 22, 2009
- Location
- Southam, Warwickshire
- 1992 190E, 1989 500SEC, 1968 220/8
Thought id do a little write up on my mini-project to install a W204 rear electric blind into my W126 SEC. I got the blind off Matt Jones advertised retro Rides for £20. Its a fairly simple and neat mechanism and doesnt require a guide pole either.
Fully extended the blind fits really well in the SEC rear window, i could only approximate its final position but it came up about 1cm from the top edge of the window.
My parcel shelf was looking pretty worse for wear, the velourish covering was faded and brittle with black marks around where the storage boxes go, so i peeled it all off.
To avoid any possible interferance with the metal structure under the parcel shelf im going to mount the blind at the same level as the flat portion of the shelf.
Im going to move the cut out bit forward of the blind and glue it back in.
Havent worked out how im going to fix the blind assembly to the shelf securly yet in a way that i can get it in and out easily.
