Hi all
has anyone had a reason and any luck getting into the the rear light cluster on a w204 (estate) facelift led type
i've had a water leak in the boot (now fixed) causing corrosion on the circuit board inside the n/s rear light cluster , i would rather not buy a new one and try and get in there to fix / clean it myself as this was misdiagnosed a few weeks back as a rear sam so i've already payed out + £500 for a rear sam and coding only for the problem to still be there
i can't find any used on ebay and new they are £250 from what i can find
