W204 Rear Washer (estate)
Dizzy
Reliant Robin with a Mercedes badge.
Hi, I have a W204 (2010) Diesel Estate and my rear screen washer has stopped. I have topped up the washer fluid but still no water appears.
Can I please confirm with you guys, that the rear washer is fed from the main washer fluid bottle under the bonnet (hood), as I cannot find another bottle at the rear. And, just to point out.. I can hear the motor so I guess the washer works okay, so could it be an air lock?
HI
Yes its fed from the main bottle. You must have a blockage/ kinked pipe/ or broken pipe somewhere. Is the actual washer jet clear?
Okay, thank you for your reply. I will check it out today ;)
If it's anything like the W203/203, the pipe feeding the jets may have broken off the wiper motor. This would mean your tailgate is filling with fluid every time you operate the rear washer.
