Can you elaborate...
Do you mean you walk up to the car, unlock remotely with the fob, it unlocks but then you have to wait 3 seconds to open the door?
Or, you press unlock on the fob and it takes 3 seconds for the lock to undo?
Or, do you mean sat inside (with the auto-lock on) it takes 3 seconds for the car to unlock itself when you pull the door handle to get out?
w20 said:Hi Many thanks for reply. WHEN OPENING car from outside with pressing button on key , once the button is pressed, you cant open the door for 3 seconds , as mentioned my prior 2010 was instant and my wife has a 2014 which is also instant , so I know there is a problem with my 2011 . Regards Tony
I know exactly what you mean - it can be extremely frustrating.
So you walk up to the door, press the remote unlock button, you can hear the door lock mechanism move, pull the handle, locked!
Our W204 doesn't do this, press the key twice and all doors unlock, no delay its instant.
My 2012 e class coupe has a delay in allowing the doors to opened after they are "unlocked" The silver lock indicators pop up but there is a delay in being allowed to open the door with the handle. Its probably only a second or just over because I've just been out and tried it. after the indicator pops up in the door you can hear another mechanism actually releasing the lock. Only a guess but as mentioned somewhere above it could be a double lock mechanism. Three seconds does sound like a fair amount of time, press the button and look at your watch and let us know the result.
Cheers..
