W204 SRS unrechable
Tubacr
Escazu
Mercedes Benz C280 2008
Hi Everyone.
I have an issue with my car a Mercedes C280 2008 gasoline (the European version of c300), some days ago I received a message about (SRS malfunction visit workshop and the airbag light on), the car was not involved in any accident and the car started as usual.
Comment.
1-I checked all Fuses.
2-I interchanged the same type relays within the SAM
3-I checked Sam connection to de harness, all cables seems to be ok.
4-All systems seem to be working fine (expects SRS module N2/10).
5-I was not able to access the SRS module by using a X431 launch.
6-I have good current (12.7v) in all fuses within front and rear SAM’s.
7-I was able to see, reach or scan the module with a Xentry/Das scanner and not able to access the module seems to be off or not installed, all other modules are working fine.
8-I checked the connections under the seats (everything seems to be ok).
9-The seatbelt light and warnings are not working.
Please let me know if any suggestion.
