Thank you very much.Hi, this is from WIS for a 2012 S204, pretty much the same I think. The document highlighted in red on the right for removing the left & right paneling is shown below the initial document.View attachment 73794 View attachment 73795 View attachment 73796
Hi! I have the same problem with my MB C220 S204 Estate 2008. Did you managed to solve this problem and if yes could you share it with me please. Thank youThank you very much.
I haven't tried removing the item ................ the reason I am removing it is because I am getting water coming in through the assembly and entering the boot area. Do you know if there is a seal/gasket as part of the install. If not I might be better using a sealant [silastic or similar] to seal the top of the stoplight where the water is coming in?
Any comment or advice greatly appreciated.
