Doodle
I do wonder if it's a side-effect of modern materials. Friction parts (pads especially) seem to last a lot longer that I remember them doing in the past, that could just be rose tinted glasses though.
Yeah, you may well be right on that.I do wonder if it's a side-effect of modern materials. Friction parts (pads especially) seem to last a lot longer that I remember them doing in the past, that could just be rose tinted glasses though.
My 2015 s205 with 19k started to get the judder/pulsating feel via the steering wheel. It was normally after a long period of driving.As a result my dealer have just replaced all discs and pads under warranty. I also decided to change the front tyres to Goodyear Efficient Performance whilst everything was off as the Contis were just becoming awful. Dealer stated that they had dealt with similar issues with this earlier model. Apparently, there are some quality control issues with the discs and the replacements are now lighter so it should solve the problem. Only time will tell but what I do know is that the car just feels much better under braking and no doubt the new tyres are helping on this.Just had the same problem on my 2016 W205 at 15,000 miles. Juddering when braking speed is between 40-50 MPH gradually stops as the car slows through 15 - 20 MPH. Not noticeable braking at higher speeds until the speed goes through 40 -50 MPH. I couldn't feel it through the steering and hardly through the brake pedal but vibration through the seat which indicated the rear brakes. Anyway dealer replaced rear discs and pads road tested and said they weren't satisfied so they changed the front pads and discs as well. All under warranty. Problem solved drives as new.
They couldn't offer a reason as to whether it was a warped disc or pad deposits; however reading the Mercedes Guide (downloaded App) the section on brakes states that the discs are made of a lightweight material and that shock-type loads when handling the discs such as when changing wheels can lead to a reduction in driving comfort.
So presumably a bit of a knock can cause a disc to go out of true and this might be the cause.
Update for what it's worth on my post 24 of 18 April 2018
2.5k miles after all pads and discs replaced problem is back, just the same as before. Car juddering when braking above 45 until speed reaches about 30. Thing is, I can't feel anything noticeable through the pedal or the steering, just seems that the whole car snatches, worse if only light pedal applied. Back to the dealer, not optimistic, but still under warranty.
Did you go to the Ombudsman, if so what happened? I'm just about at the same point with my W213 E220DI'm taking my case to the motor ombudsman. Suggest you do the same.
Hi i have the same issue with my E class w213 66 plate brake judder did any one from you guys manage to solve the issue?Hi I have a 2016 C300 coupe with 6k miles, and it's in MB Stratford upon Avon for the same issue since last Friday! I've been getting steering wheel shake during braking at speeds from 45/50mph, getting worse over 70mph. The dealer rep is waiting for a response from MB direct, but won't divulge what the issue is! I think it could be a more prevalent issue than just a few cars.
