pmcronin
Evening all. Haven’t posted for a while, as work had gotten in the way - but back to play again now.
Background - I have a 2018 C350e Premium, so it didn’t come with Burmester Audio as fitted to the Premium Plus models. I’ve already added CarPlay, via an aftermarket module ( which works really well). I’ve also upgraded the front door speakers & center speaker to Match components ( including the tweeter in the grill above the door card). So mid-range and top end are fine - but it‘s a bit weedy in the bass dept.
I can find a pair of the Burmester 8” subwoofers on eBay for about 180 euro delivered. I know swapping out the standard one on the passengers side for the Burmester is effectively plug and play, but I have some questions about the (extra) one on the drivers side:
No wrong answers here folks - just looking for your candid views, or ideally experience if you have been here already.
Thanks a mill as always - PC
- Do I need a harness, or is it sitting there pre-installed?
- Do I need to do anything to enable it, once added ( ie does it need turning on via MB-STAR?)
- Is it worth doing if I don’t add the Burmester Amp as well?
