The first thought that comes to mind was whether the correct oil, MB or known equivalent was used. Was the work carried out by an MB Indy, or Dealership? It will slip a little in first and second, but that is down to the torque converter rather than the gearbox. Seems a strange problem to have following an oil change. You say, no faults come up, were these read by a code reader or the MB Star system?Hi just had gearbox oil changed car is jerking from 1st/ 2nd has never done that before 3rd 4th up to 7 are all smooth seems like it is slipping any ideas no faults have come up .
thanks Ernie for coming back to me the oil was Mercedes oil and work done by a Mercedes approved mechanic slipping in 1st to 2nd then jerking then D coming up on the dash its going into a auto transmission garage on Friday so fingers cross fault came up something to with clutch?????The first thought that comes to mind was whether the correct oil, MB or known equivalent was used. Was the work carried out by an MB Indy, or Dealership? It will slip a little in first and second, but that is down to the torque converter rather than the gearbox. Seems a strange problem to have following an oil change. You say, no faults come up, were these read by a code reader or the MB Star system?
Ernie
