Hi, do you h
I have a 2016 C63 S205 without the performance exhaust option (no button in centre console). What would you recommend to force the valve on the X exhaust manifold open?
I want it to sound like Sport+ but as I find that too harsh for daily driving I prefer to have that noise but in Comfort!
Many thanks!
Sorry buddy I meant you should have got these for £24
[/URL]
Does the very same job but just keeps the valve open all the time, then if you was happy with the result spend £300 on a more fancy one which you could control. But anyways you would have been in the same position them ppf filters really mute the c63 that much ? I need to hear one
If your going to PCW your not going to need modules anyways once he works his magic
Hi, I’m struggling to find what you’re referring to here.Sorry buddy I meant you should have got these for £24
Mercedes A45 AMG Exhaust Valve Delete & Blanking Connector OEM | eBay
This is designed to connect into the exhaust valve harness side to eliminate the soft fault code found when disconnecting from the exhaust valve module and blanking plug to eliminate water/Debris ingress in the exhaust valve.www.ebay.co.uk
Many thanks!
