Help! - Bad luck strikes again!
W205 estate 2019 AMG-line model, with LED headlamps. I've just suffered a stone piercing a hole in the headlamp lens cover. The light still works and there doesn't appear to be any damage to the LED components, just the perspex cover itself is damaged. Is the lens cover only available as a separate part? or is it a case of being a sealed unit which requires replacement in it's entirety? If so, is it a DIY prospect or will it require coding etc?
