W205, heated mirrors as standard?
Longfellow78
Hampshire
2016 C Class 220d Amg Line
Can someone tell me please, are there heated mirrors on the base spec AMG line 2016 c class saloon?
When I turn on the rear heater the mirrors stay the same so I assume not?
Thanks.
Are they not triggered by low temperaure?
I would have thought that all models will have heated mirrors, triggered automatically.
Said that, on my old Omega there was a led indicator when the mirror heating was on - but on the Merc there's no way of knowing when it's on.
As others have said Mercedes Heated door mirrors come on automatically at a set temperature, this temperature has varied slightly on earlier models, but now with the mirror heaters on the CAN BUS I think this temperature is 10 degrees Celsius.
So won't come on in this weather but I presume one can force them on by turning on the rear screen heater?
It was just that I turned on the rear heater and the side mirrors didnt seem to clear of moisture, maybe they take a while to warm up.
Post up your VIN and some kind soul will check for you
The Mercedes I have had dealings with regarding the heated mirrors were completely separate to the Heated rear screen, and I have no reason to be believe they have changed this principle of operation.
The door mirrors get warm pretty quickly, you would certainly feel that they were on after a minute or so.
As others said they are automatic. Doubt it’s cold enough atm. My drivers side one stopped working and was fixed under warranty. Should just work, you don’t need to do anything.
The heated mirrors on the W205 are activated by 3 criteria, see this extract from WIS.
