Hi all.
I've had my c class now for two weeks and since day one I've had a slight rattle from the centre dash mounted screen. I usually turn up the music to fade it out. However I've noticed when you press the top of the screen it stops rattling for a while then comes back.
Anyone else had this issue?
My second issue is the fuse box location at passenger foot level.
It seems there is a subwoofer there and this seems to rattle that fuse box door that is just plastic against plastic. It is that bad you can hear it outside when music is turned up. I got a video of it it's that bad. Would a bit of sound deadening sponge do the trick? Or should I just send it to MB under warranty?
Other than that it's a great car! It's just niggly bits like that which start to get on ur nerves.
