stubax
Can anyone tell me if I need shorter wheel bolts when fitting the correct steel spacesaver wheel to my W205 Sport 220 Bluetech.
Only 203s needed shorter bolts for the space saver; 204s didn't. The problem was with parking brake drums on the back brakes, if you used the standard bolts on a 203, they fouled the internal mechanism for the p/b and caused expensive damage.
The 205s don't have this mechanism due to the electronic p/b, so my advice would be to try your s/s on a rear wheel and also a front wheel with the standard bolts and if the wheels turn OK you don't need to buy long bolts. I wouldn't 'rump' them up hard initially, mind, just in case, but spin the wheel while tightening.
Would you mind posting the part no. for your 205 s/s and also the cost?
Ernie
Interesting. Does the 205 not have drum brakes then at the back for the parking brake?
