W207/C207 Camber bolts??
JBM1
West Yorkshire
2009 E350 CDI Coupe
Good morning,
I have just got my 2009 e350 cdi coupe back from having hunter alignment, however the garage stated they were unable to correct the pull to the left and it was still out (left front camber at 1 degree)
I have noticed a lot of people mention this is a problem which can be fixed via using adjustment bolts.
However I have tried my best to find the correct parts and can only find the part number for the w212 (saloon) this is also the case when I asked Mercedes.
Does anybody know the correct part number for these bolts to fit the coupe and not the saloon or any links for the correct ones.
Thanks in advance
Thank you for the reply 👍
Yes I have seen plenty of recommendations for WIM however I haven’t contacted them as I live in West Yorkshire.
If tony or anyone else can give me any help or confirm the part numbers I would appreciate it.
The confusion arises because the A207/C207 isn't a W212, instead it's a W204. Look for W204 bolts. I believe that the part number for the W204 is A0003331071 (which may or may not be the same for the W212....).
Thank you,
This is my first Mercedes so I’m still trying to figure bits out. I have seen somewhere the car is based on the w204 but wasn’t sure they would fit either..
I’ll have a look for these bolts 👍
