the prince
OK so i've been given some advice so far on this but as a side issue.
I had the soaked footwell problem and on pulling the carpet up i found this wire tucked under the plastic trim covering the sill. It didn't appear to be connected to anything, so a very light pull revealed it to be around 4-5 foot in length. I've now taken off the metal panel at back of footwell and found it is the Auto Gearbox Control unit. The thing i need to know now is, where should this wire go and how is it connected to the gearbox if that's where it she be sited. Thanks.
