HI, my car used to auto-lock when driving off. I left someone in my car while I nipped to the shop and it was locked from inside. Now it won't lock when i drive off
I've checked my user manual and tried the following to no avail:
I wasn't sure whether or not to try a battery disconnect, but wasn't sure if this would create more problems!
- Opened the car from outside (remote)
- Turned the ignition to 2 (the one just before it starts!)
- Held the rocker switch in, in the upper position for about 6 seconds
- *I think I turned the ignition off after doing this, then removed the key, then started the car and went for a quick test-drive* Obviously didn't work!
