117
- Oct 28, 2005
- Location
- Exeter, Devon
- BMW 650i Sport, Range Rover V8 Autobiography, Ex 01' S500, '04 C200 CDI Coupe, '95 C200
Hi Guys,
Small issue with my 2002 CLK230 Cab
Basically, with the top down, and when the windows are shut by holding roof button after the hood has folded away, the passenger window goes up around 1cm further than the level of the drivers window, leading to an annoying rattle unless I use the window switch to manually toggle it down. Otherwise the window is absolutely fine, drops when door is opened as it should etc. anything I could do to adjust this?
