HenryHill
So I have the CLK V6 350 Cabriolet and it is on 92k and will probably go bang because of the balance shaft issue. I am planning on doing the visual check at the weekend and would also be grateful for any recommendations for a code reader. The website from which I found my engine number said that these readers can be picked up on the internet for as little as £20, is this right?
It already has a couple of issues which I hope you guys may be able to help with:
1) Electric Lumber switches are not working, any suggestions of a common fix?
2) I have a ticking/clicking which sounds like it is coming from the OSR wheel area, it is not the wheel because the noise is still there when the car idles. I have, briefly had the car up on a jack with the wheel off and it sounds like a pump or some sort??
Really do appreciate any help or guidance you can give.
Cheers
HH
Edit to add: Engine number is 27296030094977 and the car could probably do with ATF change, is this a DIY or Indy job?
Cheers
HH
