Bennal
I've bought a replacement for my ashtray; the seller listed it as an 'oddments tray' but the part box states 'parcel rack' (part no A2088100441). I suspect this is what Mercedes fitted on CLKs when the buyer chose the 'delete ashtray' spec option. It's essentially a small lined cubby hole, with a 12v socket on the right and a light at the back.
I've removed my existing ashtray and the new one will just pop in, but there's a problem. The old ashtray had a dual purpose connector containing a pair of connectors for the 12v output, and another single connector for the bulb. The new tray doesn't have any illumination around the 12v socket, but has an LED light instead. Unfortunately there is no wiring in the center console for the additional light. The new light uses the same small black block type connector that's used on the LED light in the main storage compartment of the center console.
Has anyone got any experience of fitting these? I'm guessing if I want the LED light working I'll need to disconnect the two grey wires that are currently meant for the old bulb, and re-terminate them into one of the little black block type connectors. Does anyone know where I can get these connectors from?
I've attached a few pictures to show the parts / wiring.
