I posted before about the gearbox being weird on my CLK230K, it would be like it was inbetween gears if you accelerated anything more than gently and then find a gear again, it also went into limp home mode once and displayed the EML.
Got the codes read on STAR today and they were:
P2001 Component N15/3 (ETC[EGS} control unit is defective
P2500 The Transmission has an impermissable transmission ratio
P2502 The Gear is inplausable or the transmission is slipping
P2602 The Voltage Supply of the valves is faulty
The person who plugged it in thought this indicated an issue with the plates/clutch/torque converter as opposed to being low on fluid (which was ok) or being a problem with the conductor plate.
Does this sound about right?, I'm unsure wether to get the gearbox thats in it looked at or get one that's selling on Ebay £200-300 ish with a torque converter and get someone to fit it, while putting new fluid and filter in at the same time.
Any advice would be much appreciated.
