W208 Convertible Hydralic Fluid Topup
Discussion in 'Engine' started by steveoelliott, Apr 16, 2015.
  1. steveoelliott
    steveoelliott Hardcore MB Enthusiast
    135
    Mar 8, 2013
    Car:
    CLK 230K W208
    Hi all,
    Today after reading another guide online, I found the little access panel where I can check the hydraulic fluid level for the hood.
    Mine is on the minimum marker, being as the car is 15 years old it's hardly surprising. However, is it worth going to all the effort of removing the panels etc to top it up or just leave for now.
    Thanks...
  2. Ted
    Ted MB Club Veteran
    5,724
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    You know that the level will fall to the point where the top doesn't work when you are out and there is a torrential downpour.
    With that bird from reception that you always fancied and you can't believe you pulled.
    On the way back from the pub after a few drinks to get her loosened up.
    With the only traffic car operational in the county behind you.
    Do you feel lucky?
    Well?
    Do you?
  3. OP
    OP
    steveoelliott
    135
    Mar 8, 2013
    Car:
    CLK 230K W208
    Haha....
    Well I will look at doing it in the coming weeks then. It's on min now and works fine but clearly it needs topping up. It's a shame it's not easily accessible and you have to strip stuff out just to top the level up.
    Thanks...
    1 person likes this.
  4. OP
    OP
    steveoelliott
    135
    Mar 8, 2013
    Car:
    CLK 230K W208
    I read another guide for a Jag where it stated with the roof raised the level should be on min and fully lowered should be on max.
    Does anybody know if this is true for the MB?
  5. Hawkwind
    Hawkwind Hardcore MB Enthusiast
    477
    Oct 2, 2013
    Brighton
    Car:
    CLK 320
    That reminds me, I must check the level on mine and I would also like to know the answer to your question.
  6. OP
    OP
    steveoelliott
    135
    Mar 8, 2013
    Car:
    CLK 230K W208
    Does anybody know?
  7. the prince
    the prince Hardcore MB Enthusiast
    125
    Sep 6, 2014
    Sheffield
    Car:
    2001 CLK 230k
    Anyone know the correct MB hydraulic fluid for roof pump?
Share This Page
