Teesside71
hi all, 1st post on here.
I've had my w208 for about 6 months now, and though right its time to sort the roof out. problem is as follows
however i found the following in the rear a208 695 00 30 which is described as a cover, and is related to the roof, however I'm not sure where it belong. please see attached pic, item 12.
on manually closing roof with pressure screw in off mode when roof is deployed, the car will lock both roof cover and lock roof rear, so again hydraulics are working sort of.
scanned with my icarsoft and received the following generic code B1650-000. Voltage to limit switches is faulty. Which suggests roof sensor.
any advice appreciated
TIA
- open roof from above, all windows retract
- rear headrests do not move as in the down position, however they do work via the up/down switch on dash
- pretty much nothing after that. I've bypassed the boot slide cover just in case
- Oil level is fine, rear cover with the 20 odd bolts has been removed as well as all carpet
- no apparent hydraulic leaks from pump or rams
TIA
