Hi folks,
Water had been trickling into my passenger footwell after heavy rain or carwashes for the past few months. I had assumed that something had corroded around the window seal or behind the front wheel, but from reading the forums it appears that the problem is most likely a blockage in the drain at the air intake. I plan to clean the blockage out this evening.
Anyway, the water appears to have damaged the blower control, because the blower will not switch off (even when they keys are removed from the ignition). I've had to resort to removing the blower fuse when the car is not in use, so I'd like to have a go at fixing this ASAP. Does anyone have any pointers on how to do this? Any do's/don'ts? I've seen illustrated howtos for other models posted on this forum, but am a complete novice and would really appreciate some help.
Cheers.
Cheers.
