W208 Door Handle Remove
Discussion in 'Bodywork' started by steveoelliott, Apr 25, 2014.
  1. steveoelliott
    steveoelliott Hardcore MB Enthusiast
    129
    Mar 8, 2013
    Car:
    CLK 230K W208
    Hi all,
    To remove the door handle on a W208 (to spray the door) do the door cards have to come off? I presume they will.
    Thanks...
  2. Grey Area
    Grey Area Hardcore MB Enthusiast
    145
    May 24, 2011
    Norwich
    Car:
    '98 W202 C230K
    On the w202 c class from a similar era, the door handles are held in by the lock cylinder part of the handle, and this is removed by loosening a small grub screw in the side of the door under the seal.
    Click the link to see a photo of the w202 set up, if you open the door and pull the seal out of its recess (don't tear it) you may well find a small hole level with the door handle. If it's there you should be able to remove the door handle without taking the door card off.
    Hope that helps.
    http://forums.mercedesclub.org.uk/attachment.php?attachmentid=8915&d=1254163523
  3. OP
    OP
    steveoelliott
    129
    Mar 8, 2013
    Car:
    CLK 230K W208
    Thanks... I imagine it will be similar on a W208.
    It's not me who will be doing but the body shop. I'm just never keen on door cards getting removed. They never go back the same.
  4. andy27168
    andy27168 Hardcore MB Enthusiast
    4,223
    Nov 27, 2004
    Southampton
    Car:
    1997 C230K, 1999 C43/55 AMG
    As above I can confirm that door handle removal on a 208 is the same as the 202, but do make sure that the grub screw does not have to be removed only loosened, if you remove it completely you more than likely loose it in the door.
  5. OP
    OP
    steveoelliott
    129
    Mar 8, 2013
    Car:
    CLK 230K W208
    Thanks folks...
Share This Page
