W208 Exhaust Heat Shield Fixings
Wilfie
CLK320 W208
Can anyone tell me what sort of fixing is used to secure the shield to the bottom of the car? One end has come loose and it clearly isn't just a case of bolting it back!
I have just remembered the search button!
They are strangely shaped nuts that holds the heat shield on. They T shaped, with an small 8mm head. The nut fits on to a thread protruding from the bottom of the car. I had to take one off last week to put a big washer under it.. The head rounded as soon as I got a socket on to it. I got it off in the end with mole grips. I could not find a suitable replacement nut, it has a very coarse thread. I managed to fit a wingnut, which seems to hold tight until I get the correct one. I noticed another part of the heat shield coming loose, but it is behind the rear box, so will be more of a bother to replace. The aluminium of the heat shield seems to disintegrate under the flat head of the retaining nut.
Great, cheers. I will get it up in the air and attack it tomorrow.
